Yeni Orient Mako II ( FAA02002D )
Mesaj tiktak98 » 26 Şub 2016, 20:39
Arkadaslar ,
Bu Yeni mako Dan haberdar olan var mi forumda ?
http://www.seriouswatches.com/orient/orient-faa02002d-aa02002d.html
Tam kodu mavi olan icin FAA02002D.
Mekanizmasi yenilenmis , push button kuculmus , yenilenmis...
Alma dusuncem var , gore bildigim kadariyla eBay de 2 saticida var , biri ustteki link biri de Rusyada.
tiktak98
Kayıt: 21 Şub 2012, 14:16
Re: Yeni Orient Mako II ( FAA02002D )
Mesaj oserin » 27 Şub 2016, 18:49
Bir de gün pencersini kaldırsalarmış, bir mako daha alırdım :thumbup:
oserin
Kayıt: 21 Nis 2014, 19:07
Mesaj argentum » 28 Şub 2016, 12:28
Japonlar gün penceresinden vazgeçemez, ben de sevmiyorum.
argentum
Kayıt: 27 Ağu 2013, 09:41
Mesaj tiktak98 » 29 Şub 2016, 15:58
Saticidan soyle bi yanit geldi;
bsolutely! It's a brand new movement that was introduced last December by Orient. The big difference between the old 46943 and this F6922 is that the latter has hand winding, hacking and the day is operated with the crown, rather than a separate crown at 2 o'clock. It will be introduced in various iterations throughout 2016. The new Bambino model will also feature a similar movement, albeit without the day.
Orient had the 40N52 (etc) and 40751 movements that it used for the more expensive models. The F6922 is meant to bring all the features for the lower price ranges, with little to no drawbacks.
Orient is slowly introducing the new models, we're expecting several new watches with this particular movement within a month or 2.
Bu Yeni mekanizmali makoyla mako USA modeli arasinda kaldim.MAko USA Safir camli ve solid end Link li , normal makoyla farklari bunlar..bu Yeni model de mineral cam var
tiktak98
Mesaj tiktak98 » 02 Mar 2016, 20:52
Forumda eskiden Cok aktif olarak gordugum kisileri goremiyorum,sanirim ugramiyolar artik buralara.
tiktak98
Mesaj mehmetbeyy » 17 Mar 2017, 22:42
Merhaba, ben de yeni orient makolardan bir tane edinmeyi düşünüyorum ama çok bir bilgiye ulaşamadım. Örneğin mako 2 ile mako 2 ray arasında ne gibi farklar var, safir cam kinusunu da öğrendiğim iyi oldu, bilgi verebilecek olursa çok memnun olurum
mehmetbeyy
Kayıt: 11 May 2016, 01:25
Mesaj Başaran » 17 Mar 2017, 22:47
Merhaba.
Dışardan almanıza gerek yok.n11 satıyor.995 TL.
Başaran
Kayıt: 24 Şub 2016, 20:39
Mesaj zekayi » 18 Mar 2017, 08:02
Bence güzel olmuş
zekayi
Kayıt: 30 Eyl 2014, 22:46
Bu forumu gezen kullanıcılar: Altar ve 144 misafir
