Saat Terim A癟覺klamalar覺: Beat Error / Amplitude / Lift Angle
Mesaj powerwandata » 15 Ara 2014, 17:13
Merhaba;
Baz覺 saat terimlerinin T羹rk癟elerine ihtiyac覺m var, dolay覺s覺yla deneyimli aabeylerimden yard覺m bekliyorum.
Beat Error
Lift Angle
Amplitude
powerwandata
Kay覺t: 11 Haz 2013, 09:37
Re: Saat Terimlerinin T羹rk癟eleri
Mesaj Architecte » 17 Ara 2014, 01:16
Alarm -Alarm
Altimetre-Deniz seviyesi 繹l癟羹m羹
Analog- Digital- Akrep yelkovan art覺, g繹stergeli kadran
Analog-Akrep yelkovan kadran
Annual Calendar-Senelik Takvim
Aperture-Aral覺k
Auto Repeat Countdown Timer-Otomatik Baa Almal覺 Geri Say覺m Sayac覺
Automatic Winding Movement-Otomatik Kurmal覺 Mekanizma
Balance Spring - Denge Yay覺
Balance Wheel - Volan
Barrel - Yay Tamburu
Bezel-er癟eve
Bi-Directional Rotating Bezel Her Y繹ne D繹nebilen er癟eve
This is a title- ift y繹nl羹 bezel
Bracelet - Metal Bilezik
Breguet Spring - Breguet Yay覺
Bridge - Eik
Calendar - Takvim
Cambered - Eri ark
Caliber or Calibre - Kalibre
Case - Kasa
Chronograph - Kronograf
Chronometer - Kronometre
Complication - Sofistike Saat
COSC -Controle Officiel Suisse des Chronometres
Countdown Timer - Geri Say覺m Sayac覺
Crown (Stem, Pin)
Crystal - Kristal
Day/Date - G羹n/Tarih
Day/Night or AM/PM Indicator - G羹n /Gece veya AM/PM G繹stergesi
Deployment (Deployant) Buckle - A癟ma (Deployant) Tokas覺
Digital Display - Dijital Ekran
Dual Time - ift Zaman Dilimi
Duo Display - ift G繹sterge
Dial - Kadran
Elapsed Time Rotating Bezel - Ge癟en Zaman覺 G繹steren D繹ner er癟eve
EOL- Pil zay覺f
Engine Turning/Turned - Menevi 襤leme (Guilloche)
Equation Of Time or EOT - Zaman Elenim veya EOT
Escapement - Saat Maas覺 (Eapman)
Fly-Back Chronograph - Otomatik Olarak S覺f覺ra D繹nen Kronometre
Function - 襤lev
Gear Train - Dili Tak覺m覺
GMT Time Zone - GMT'ye G繹re Zaman Dilimi
Gold Plating - Alt覺n Kaplama
Guilloche- Motif ileme
Hairspring - Denge Yay覺
Helium Escape Valve - Helyum Tahliye Valf覺
Horology - Horoloji
Index Hour Marker - Saat 襤mi
Jewels - Talar
Jump Hour/Minutes - S覺癟ramal覺 Saat/Dakikalar
Lap Timer - Etap Zamanlay覺c覺s覺
Lever Escapement - Eapman Kolu
Liquid Crystal Display (LCD) - Likit Kristal Ekran (LCD)
Luminous - Parlak
Lugs - er癟eve Kula覺
Main Plate - Ana Plaka
Mainspring - Ana Yay
Manual Wind Movement - Elle Kurmal覺 Mekanizma
Marine Chronometer - Marine Tipi Kronometre
Measurement Conversion - l癟羹 D繹n羹t羹rme
Mechanical Movement - Mekanik Saat Mekanizmas覺
Micron - Mikron
Minute Repeater
Mono (Single) Pusher Chronograph - Tek D羹meli Kronometre
Moonphase - Ay Evresi
Mother of Pearl - Sedef
Movement - Mekanizma
Numerals - Numaralar
Perpetual Calendar - S羹reen Takvim
Platinum - Platinyum- 癟ok deerli bir metal
Power Reserve Indicator - Kalan G羹癟 G繹stergesi
Pulsimeter- Nab覺z 繹l癟er
Not: Al覺nt覺d覺r
Tecr羹be, hayatta yediimiz kaz覺klar覺n toplam覺d覺r'
Architecte
Ya: 52
Kay覺t: 11 Nis 2014, 00:56
Mesaj Modern60 » 19 Ara 2014, 02:21
Say覺n memojan bilgileri biraz d羹zeltmek gerekecek...altimeter y羹kseklik 繹l癟er, aperture aral覺k demektir, analog geleneksel, digital say覺sal,camfered yada cambered kubbe, crown tepe, complication kar覺覺k d羹zenekli, fly-back chrobnoraph-h覺zl覺 yeniden sayma kronograf覺, lug boynuz, minute repeater sesli zaman okuyucu, main plate platin, mainspring zemberek, marine chronometer denizci kronometresi, mono pusher chronograph tek tulu kronograf, perpetuel s羹rekli devaml覺, turning makine de ilenmi, gibi olmal覺. 襤sterseniz deitirin.
Modern60
Contributor
Kay覺t: 02 Mar 2010, 01:40
Mesaj Architecte » 19 Ara 2014, 03:34
Altimeter zaten ''y羹kseklik 繹l癟er'' demektir. Kara seviyesi deniz 羹zerinden 繹l癟羹lm羹yor mu? baka ne olabilir? Boy 繹l癟羹s羹 m羹? :D
Aparture- zaten ''Aral覺k'' olduu yaz覺yor.
Lug zaten ''癟er癟eve kula覺'' olduu yaz覺yor. (Kulak- boynuz)
crown- zaten ''pin'' olduu yaz覺yor. Pin- uzant覺.
Complication- zaten ''sofistike'' olduu yaz覺yor. Sofistike, 癟ok kar覺覺k ilemler. (felsefi terim)
Fly-Back Chronograph zaten ''s覺f覺ra doru'' d繹nebilen olduu yaz覺yor.
Marine- ''denizcilikle ilgili'' anla覺lmamas覺 imkans覺z diye d羹羹nd羹m.
Mono Single Pusher Chronograph - zaten ''Tek D羹meli (tulu) Kronometre olduu yaz覺yor.
Perpetual Calendar - zaten ''S羹reen Takvim'' olduu yaz覺yor. S羹reen- devaml覺
Neyi deitireyim say覺n Moderno60 arkada覺m?
Architecte
Ya: 52
Mesaj asymptote » 19 Ara 2014, 11:40
memojan yazd覺:Altimeter zaten ''y羹kseklik 繹l癟er'' demektir. Kara seviyesi deniz 羹zerinden 繹l癟羹lm羹yor mu? baka ne olabilir? Boy 繹l癟羹s羹 m羹? :D
modern60 ne der bilemem ama, zaten anla覺l覺yor, bence hi癟 deitirme..
Kay覺t: 11 Ara 2010, 14:28
Mesaj Architecte » 19 Ara 2014, 19:25
Zaten deitirmeyeceim. Umar覺m k覺r覺lmaz bize ;)
Architecte
Ya: 52
Mesaj ErsinGS » 19 Ara 2014, 23:04
modern60 羹stad覺 dinlemekte yarar olabilir.
Burada hepimiz birbirinizden bir eyler 繹reniyoruz.
Mainspring zemberek manas覺na geliyor mesela
ErsinGS
Ya: 61
Kay覺t: 10 Ara 2011, 00:05
Mesaj asymptote » 20 Ara 2014, 00:00
I ben, love seni, you seviyorum..
Bu forumu gezen kullan覺c覺lar: Hi癟 bir kay覺tl覺 kullan覺c覺 yok ve 7 misafir
