PVD Kaplaman覺n Avantaj ve Dezavantajlar覺 Nedir?
Mesaj Triton » 22 Haz 2013, 13:06
Forumdaki konular覺 incelerken 繹zellikle PVD kaplama ile ilgili fazla detay bulamad覺m. Yabanc覺 forumlar覺 ve interneti de arat覺r覺yorum ama arkadalardan ilgisi olanlar, 繹zellikle asymptote, u PVD kaplama hakk覺nda detay bilgiye sahiplerse paylaabilirler mi?
Neden b繹yle bir se癟enek oluturulmu? Gerek癟esi nedir? Art覺 ve eksileri nelerdir?
Peinen tk ler....
"I fear the day when the technology overlaps with our humanity. The world will only have a generation of idiots." Albert Einstein
Triton
Ya: 66
Kay覺t: 24 Haz 2012, 12:14
Re: PVD Kaplaman覺n Avantaj ve Dezavantajlar覺 Nedir?
Mesaj Wwtr » 22 Haz 2013, 13:39
Siz de g繹rm羹s羹n羹zd羹r ama arivde kalmas覺 amac覺yla 襤ngilizce bir yorum paylamak istedim.
StealthMax PVD vs. Mil-Spec Teflon Coating
CERAMIC:
Pro's: Relatively inexpensive. cost of product is not high and application does not required specialized equipment. It can be removed and refinished should it be damaged. relatively tough (tougher than teflon, but not as tough as PVD). available in a wide variety of colors and coating finishes (flat to glossy).
Cons: Surface must be blasted in order to give the coating proper adhesion. Relative toughness (more susceptible to scratching than PVD). Applicators require a special license (the stuff is toxic)
TEFLON:
Pros: Like ceramic it's application is very similar and requires prepping the surface before application. This means that Like ceramic, teflon can only be applied to blasted surfaces. If you have the right tools (compressor, blasting cabinet, application tools and a good toaster oven), you can apply it at home yourself. It comes in a wide variety of colors, but definitely not as many as ceramic. Also darker colors and earth tones apply better than lighter ones. It is tough stuff, but it can chip and scratch. However it is easily repairable for relatively little money. it is the cheapest and easiest to apply of all 3 coatings.
Cons:It is a bit less impact resistant than ceramic and available in fewer colors. Also, the same issue about bracelets, stated below, applies. It can only be applied to blasted surfaces.
PVD:
Pros: bonds at a molecular level which makes it fairly tough stuff. Can coat different kinds of metal finishes (satin, polished or blasted).
Cons: Expensive. requires specialized equipment to apply. if scratched it cannot be repaired (at least not without removing a layer of surface material from the entire piece). Very few colors available. Very few companies will do it (and most of those are don't do it exclusively for watches, but rather do watches if enough pieces are available aside from their primary business)
Daha fazlas覺 ve kaynak:
http://forums.watchuseek.com/f2/stealthmax-pvd-vs-mil-spec-teflon-coating-248699.html
Wwtr
Kay覺t: 20 Mar 2010, 14:02
Mesaj drk » 22 Haz 2013, 14:11
PVD=physical vapor deposition kelimelerinin k覺saltmas覺, bir kaplama bi癟imi. Ama癟, daha sert ve dayan覺kl覺(saatler i癟in farkl覺 renkte) y羹zey alan覺 oluturmak. eitli pvd t羹rleri bulunmakta, sekt繹rde en 癟ok kullan覺lanlardan biri DLC(diamond like coating). Kaplaman覺n art覺lar覺, saatin metal y羹zeyinin rengini deitirebilirsiniz, 癟elik y羹zeye g繹re 癟ok daha sert bir y羹zey oluturduunuzdan saatiniz 癟izilmelere kar覺 daha dayan覺kl覺 olur. Eksileri, y羹zey sertlii sadece 癟ok ince bir film tabakas覺yla s覺n覺rl覺 kald覺覺ndan y羹zeye zarar gelirse alttan 癟覺plak metal g繹r羹n羹m羹 癟覺kar. Kaplama saat 癟izilmez demek deildir癟 elik y羹zeye polisaj-satinaj uygulayarak 癟izikler yok edilebilirken pvd kaplama da b繹yle bir se癟enek yoktur, tek 癟繹z羹m kaplamay覺 tamamen s繹k羹p kasay覺 tekrar kaplamakt覺r.
ahsen kaplama saatlere 癟ok olumlu g繹zle bakm覺yorum. Ama癟 siyah g繹r羹n羹m ise k覺r覺lma riskine ramen seramik saatlerden yanay覺m.
Kay覺t: 20 Nis 2010, 23:24
Mesaj Triton » 23 Haz 2013, 13:11
Tk ederim.
Yeterli oldu.
B繹yle bir saat almak niyetim var. Ancak d羹羹nmek gerekiyor sonucuna vard覺m....
Triton
Ya: 66
Mesaj selcukkul » 06 Eki 2015, 11:23
sadece bu soruya cevap yazmak i癟in 羹ye oldum.PVD kaplama vakum alt覺nda yap覺lan 癟ok y羹zsek sertlie sahip bir kaplama t羹r羹d羹r. 癟eliin yakla覺k 3 kat覺 sertlie sahiptir.癟izilmelere ve a覺nmalara kar覺 癟ok dayan覺kl覺d覺r. deiik renklerde yap覺labilir ama genelde saat 羹zerinde siyah kaplamay覺 tercih ediyorlar. bu siyah kaplama 癟eitli metaryellerle olabilir . aluminyum titanyum ala覺m覺 titanyum karbon kaplama ...gibi. v羹cut i癟in hi癟bir zarar覺 yoktur 癟evreci bir kaplamad覺r.s覺n覺rs覺z renk scalas覺 olsada belirli renkler 癟ounluktad覺r. alt覺n rengi, bak覺r rengi, siyah,癟eliin kendi rengi gibi...
selcukkul
Kay覺t: 06 Eki 2015, 11:06
Mesaj Cotton » 06 Eki 2015, 14:09
Kaplamadan pek anlamam ama esas olan saatin ana metalinin cinsi ne ise d覺 y羹zeyde i癟ide ayn覺 cins olmal覺. Saat kullan覺m覺n覺n y覺llar boyutunda bu kendini hissettirecektir.
Kaplaman覺n uzun s羹reli dayan覺m覺 tart覺覺l覺r.
Mevcut emektar saatimin 23 y覺ll覺k ge癟miinde bilerek yada bilmeyerek bir 癟ok zorlu y覺pranma s羹recinde en fazla ter ve kirle kar覺laan alt y羹zeyinin bir resmini paylamak istedim.
Hi癟 bir eye cesaret edemeyen, hi癟 bir eye 羹mit beslemesin !
Cotton
Ya: 54
Kay覺t: 22 Au 2014, 09:24
Mesaj selcukkul » 06 Eki 2015, 14:24
metallerin y羹zeyinin belirli bir dayan覺m覺 dayan覺m覺 vrd覺r. gerek atmosfere kars覺 gerek birbiriyle temas ettii y羹zeye kar覺. bu karakteristlik 繹zellikler her metalde ve temaz esttii y羹zeye g繹re deikenlik g繹sterir. bu t羹zeylerin dayan覺m覺n覺 artt覺rmak i癟in kaplamalar 羹retilmitir. 癟羹nk羹 metalerin kendisini bu ekilde 羹retmek hem 癟ok maliyetli hemde 癟ok zaman alan bir ilemdir.
saat konusuna gelirsek, saatler herzaman v羹cudumuza temas ettii i癟in, v羹cuttaki ter bir zaman sonra saatlerin alt覺nda korozyona sebep olur. bunu engellemek i癟in saatin kasas覺n覺 paslanmaz 癟elikten yaparlar. hatta kasa rengi farkl覺 olsada alt kapak beyaz olan saatleri bilirsiniz.
bu seferde tek renk yani metalin kendi renginde saatler 羹retilir, farkl覺 g繹rsellikler i癟in sat kasalar覺na farkl覺 kaplamalar yap覺lm覺t覺r (alt覺n kaplama,bak覺r kaplama gibi) fakat bunlar覺n tere dayan覺m覺 azd覺r.
ite bu noktada pvd kaplama en iyi 癟繹z羹md羹r. hem 癟evreci olmas覺 hem asidik ve bazik ortamlara kar覺 dayan覺m覺 癟ok y羹ksektir. sertlii ve zor癟izilmesini yukar覺da baksetmitim.
sonu癟 olarak bir saat i癟in ne kadar kaliteli 癟elik kullan覺rsan覺z kullan覺n( bu316L paslanmaz 癟eliktir) hi癟 bir zaman bir PVD kaplaman覺n karakteristlik 繹zelliklerini g繹stermez.
ben 18 y覺ld覺r pvd kaplama yap覺yorum bu y羹zden bunlar覺 bilerek yaz覺yorum
selcukkul
Mesaj selcukkul » 06 Eki 2015, 15:13
Cotton yazd覺:Kaplamadan pek anlamam ama esas olan saatin ana metalinin cinsi ne ise d覺 y羹zeyde i癟ide ayn覺 cins olmal覺. Saat kullan覺m覺n覺n y覺llar boyutunda bu kendini hissettirecektir.
sizin saatinizin kasas覺 zamak ve terden korozyok olmu. alt kapak paslanmaz olduu i癟in hi癟bir korozyon yok. bir 150 y覺l da biey olmaz
selcukkul
Bu forumu gezen kullan覺c覺lar: Hi癟 bir kay覺tl覺 kullan覺c覺 yok ve 46 misafir
