1991'den bugüne fiyat, kalite ve kusursuz hizmeti bir arada sunan Sami Saat ve Mücevherat
dünyanın en prestijli lüks saat markaları ve benzersiz saat koleksiyonlarına ev sahipliği yapıyor.
2013 Lamborghini Aventador Roadster
Mesaj drk » 12 Kas 2012, 22:04
CHASSIS AND BODY
Frame: Carbon fiber monocoque with Aluminium front and rear frames
Body: Carbon fiber engine bonnet, movable spoiler and side air inlets; Aluminium front bonnet, front fenders and doors; SMC rear fender and rocker cover High pressure RTM carbon fiber Hard Top matt black painted
Mirrors: External mirror electrically foldable
Rear spoiler: Moveable - 3 positions depending on speed and drive select mode
SUSPENSION
Suspension: Front and rear horizontal mono-tube damper with push-rod system
TYRES AND WHEELS
ESP: ESP/ ABS with different ESP charecteristics managed by drive select mode
Steering: Steering Gear with 3 different servortonic charcteristics managed by drive select mode
Front tires: Pirelli 255/35 ZR19
Rear tires: Pirelli 335/30 ZR20
Front wheels: 19'' x 9J
Rear wheels: 20'' x 12J
Curb-to-curb turning circle: 12.5 m (41.0 ft)
AIRBAGS
Airbags: Front dual stage driver airbag and front adaptive passenger airbag; seats with side “head-thorax” airbags; passenger and driver knee airbags
BRAKES
Brakes: Dual hydraulic circuit brake system with vacuum brake booster; front and rear CCB, 6-cylinder brake callipers, 4-cylinder brake callipers Ø 400 x 38 mm – Ø 380 x 38 mm
ENGINE
Type: V12, 60°, MPI
Displacement: 6,498 cm³ (396.5 cu.in.)
Bore and stroke: Ø 95 mm x 76,4 mm
Valve gear: Variable valve timing electronically controlled
Compression ratio: 11.8 (± 0.2) : 1
Maximum power: 700 HP (515 kW) @ 8,250 RPM
Maximum torque: 690 Nm (507 lbft) @ 5,500 RPM
Emission class: EURO 5 - LEV 2
Emission control system: Catalytic converters with lambda sensors
Cooling system: Water and oil cooling system in the rear with variable air inlets
Engine management system: Lamborghini Iniezione Elettronica (LIE) with Ion current analysis
Lubrification system: Dry sump
DRIVETRAIN
Type of transmission: 4WD with Haldex generation IV
Gearbox: 7 speed ISR, shifting characteristic depending on drive select mode
Clutch: Dry double plate clutch, Ø 235 mm
Standard: AMT
PERFORMANCE
Top speed: 350 km/h (217 mph)
Acceleration 0-100 km/h (0-62 mph): 3.0 s
DIMENSIONS
Wheelbase: 2,700 mm (106.30 in)
Overall length: 4,780 mm (188.19 in)
Overall width (excluding mirrors): 2,030 mm (79.92 in)
Overall height: 1,136 mm (44.72 in)
Front track: 1,720 mm (67.72 in)
Rear track: 1,700 mm (66.93 in)
Dry weight: 1,625 kg (3,583 lb)
Weight/Power: 2.32 kg/HP (5.12 lb/HP)
Weight distribution (front - rear): 43 % - 57 %
CAPACITIES
Fuel tank capacity: 90 l (23.8 gal.)
Engine oil capacity: 13 l (3.4 gal.)
Engine coolant capacity: 25 l (6.6 gal.)
FUEL CONSUMPTION * E-GEAR TRANSMISSION
Urban consumption: 24.7 l/100 km
Extra urban consumption: 10.7 l/100 km
Combined consumption: 16.0 l/100 km
CO2 emission: 370 g/km
Liste fiyatı: 300,000euro + vergiler
Re: 2013 Lamborghini Aventador Roadster
Mesaj aokyy » 12 Kas 2012, 22:09
Yorum yapmaya bile gerek yok.
aokyy
Kayıt: 11 Ara 2011, 14:40
Mesaj AboveTheRim » 12 Kas 2012, 22:25
Hayat bazen/kimisine Lamborghini Aventador Roadster
Mutluluk başarıya, başarı ise zamanı değerlendirmeye bağlıdır.
AboveTheRim
Yaş: 35
Kayıt: 08 Kas 2011, 05:06
Mesaj herofb » 12 Kas 2012, 22:31
yok artık acayip derecede artık nasıl tarif edilirse o kadar muhteşem olmuş :champ:
Mesaj Frax » 12 Kas 2012, 23:02
Traktörcünün güzünü seveyim :champ:
Mesaj FatihGS » 12 Kas 2012, 23:05
Araba nerde? :)
FatihGS
Kayıt: 21 May 2012, 22:30
Mesaj 2fast4u » 12 Kas 2012, 23:54
bugun tesaduf soyle bır vıdeo ızlemıstım...
Mesaj Baran » 12 Kas 2012, 23:58
Biraz daha yuruseler o motor onu üzerde kısada motoru kaldırmak zor tabi.
