Dünyanin En Komplike Kol Saati - Franck Müller
Mesaj Clk » 27 Oca 2010, 18:41
Ilk bakista dizayn olarak klasik Frank Müller dizayni olarak göze carpiyor ama yakindan baktiginizda bu saatin pekte normal bir saat olmadigini anlayacaksiniz. Su an incelemekte oldugunuz saat dünyanin en komplike kol saati... Özellikleri mi?
• Hour, minute & second display
1. Day-Night display
2. Grand strike
3. Small strike
4. Silence
5. Minute Repeater
6. Westminster Carillon on 4 gong
7. Programming of the Grand strike-Small strike function with a waterprof push-piece and display on the dial
8. Programming of the Strike-Silence function with a waterprof push-piece and display on the dial
9. Lifting-lever mechanism of the strike when in hand-setting position
10. Mechanism which not allow the start of a new strike if the precedent is not to the end
11. Bolting mechanism of the hand-setting during the strike
12. Transmission mechanism to the hammer which permit the adaptation to different shape of the gong
13. Movement power reserve indicator
14. Strike power reserve indicator
15. Silent Centrifugal governor of the rate of the strike
16. Flying Tourbillon on a ball bearing with ceramic balls
17. Balance wheel with adjustment screws in gold, without index
18. Breguet overcoil with Phillips curve
19. Tourbillon carriage, without any brige, visible in the dial
20. Automatic self-winding-mechanism of the movment with platinum micro rotor
21. Automatic self-winding-mechanism of the Westminster carillon with a platinum micro rotor
22. Perpetual Calendar
23. Display of the days
24. Display of the months
25. Retrograde Date
26. Secular Calendar
27. Display of the year up to 999 years
28. Bissextile year display
29. Indication of the secular years
30. Astronomic moon : deviation of 6.8 seconds for each lunation representing an error of one day every 1000 years)
31. Equation of time
32. Two additional time-zones
33. Chronograph incorporated with tree column-weels
34. Instantaneous minutes counter
35. Hours counter incorporeted in the mechanism of chronograph, retrograde hand display
36. Fly-back hand mechanism
Saatin modeli Aeternitas Mega 4. Hersey Frank Müller mühendisleri ve ileri gelen saat ustalari icin bir proje olarak baslamisti ama ortaya cikan sonuc her 1000 yilda sadece 1 gün sapma yapan dünyanin en komplike kol saati. 2.7 Milyon dolarlik fiyati ile bizler icin sadece görsel sölen olan bu saat 1483 özel parcadan olusuyor. 2.7 milyon dolarlik fiyati, saati ayrica müzayedeler disinda satilan en pahali kol saati yapiyor.
Üretimi 5 yil süren 36 komplikasyonlu bu saat, komplikasyonlarindan 25 tanesinin görülmesine olanak sagliyor.
Unutmadan belirmek lazim, perpetual takvim neredeyse hatasiz olarak gelecek 999 yil hizmetinizde.
Not: Mekanizmanin kalinligini 2 mm olarak okudum ama kesin birsey söylemek icin daha fazla arastirma yapmak lazim....
Saat ve teknoloji kavramlarini bir sanat eseri edasi ile bir araya getirip, insanliga böyle bir hediye sunan Frank Müller firmasina sahsim adina tesekkür ederim.
Well done boyz :)
Re: Dünyanin En Komplike Kol Saati-Frank Müller
Mesaj Frax » 27 Oca 2010, 19:56
Resimlerle ayrıntılı açıklama olsa iyi olur hakikaten fazlasıyla komplike :)
Fiyatı bence abartılı. ( oturduğun yerden konuşmak kolay diyebilirsiniz :D )
Mesaj everywhere » 27 Oca 2010, 20:55
açıkcası bu saat olmamış 7 tane buton cidden çok çirkin duruyor.bence önemli olan 30 tane 40 tane komplikasyonu bi saatin içine koymak değil mesele önemli olan bu kadar özelliği estetik bir şekilde bir kasaya yerleştirmek,saat göstergesi tam bir kaos yani bilmiyorum bu saat kolda nasıl durur.bu saati üretme süreci biraz kendilerini ispatlama çabası olmuş biz yapabilirizi göstermek olmuş.vacheron constantinein bir saati vardı yüksek komplikasyona sahip mesela o çok daha güzel ama bence bu saat olmamış.ama son söz olarak şunu söylemeden edemeyeceğim mekanizmayı gösteren resime bakmaktan da kendimi alamadım:)
everywhere
Kayıt: 17 Kas 2009, 15:40
Mesaj everywhere » 27 Oca 2010, 20:58
bu arada 999 yıllık takvim benim gibi perpetual hastası bir insanın da ağzınını açık bırakmaya yetiyor,avatarımdaki iwc nin 300 yıllık takvimi birden anlamını yitiryor.
everywhere
Mesaj Clk » 27 Oca 2010, 21:01
Everywhere, simdi benim IWC perpetualime haksizlik etme biri 27.000 Euro öbürü 2.7 milyon :) IWC Perpetual hala gönlümde ki saat ve alana kadar öyle kalmaya devam edecek....
Mesaj nickynick » 27 Oca 2010, 21:01
everywhere yazdı:açıkcası bu saat olmamış 7 tane buton cidden çok çirkin duruyor.bence önemli olan 30 tane 40 tane komplikasyonu bi saatin içine koymak değil mesele önemli olan bu kadar özelliği estetik bir şekilde bir kasaya yerleştirmek,saat göstergesi tam bir kaos yani bilmiyorum bu saat kolda nasıl durur.bu saati üretme süreci biraz kendilerini ispatlama çabası olmuş biz yapabilirizi göstermek olmuş.vacheron constantinein bir saati vardı yüksek komplikasyona sahip mesela o çok daha güzel ama bence bu saat olmamış.ama son söz olarak şunu söylemeden edemeyeceğim mekanizmayı gösteren resime bakmaktan da kendimi alamadım:)
Hmm, olmamış diyosun yani everywhere :lol:
Bu arada, IWC Perpetual in 300 değil, 400 yıl diye biliyorum Perpetuali..
Mesaj Frax » 27 Oca 2010, 21:20
Nicky Nick yazdı:
Ben de olmamış diyorum bu saati takanın yanında kullanma klavuzuyla gezmesi lazım sadece prestij için yapılmış bir saat.
Ayrıca 300 yıl 400 yıl ne farkeder sanki onu görebilecek var.Torunlar zaten atar onu bir köşeye eninde sonunda :D
Mesaj nickynick » 27 Oca 2010, 21:22
frax1 yazdı:
Nicky Nick yazdı:
Aslında hangimiz biraz prestije hayır diyebilirizki :P
Bu forumu gezen kullanıcılar: gargamell ve 238 misafir
